parallel port under linux
could anybody help a linux-labview beginner?
i'm trying to write to my parallel port. but labview is obviousely not set
up for this. does anywone happen to have a vi which can do that?
best of regards
michael h. fischer
cell: +43 664 1254415
fax: +34 664 1265930
icq: #61578912
vienna university
institute of geology
geochronology laboratories
althanstrasse 14 / 2a482
a - 1090 vienna (austria)
web: www.univie.ac.at/geologie/fischer/
wap: www.univie.ac.at/geochron/wap/
(4,087 Views)
"michael h. fischer" writes:
Michael,
I'm not sure how you adress the parallel port.
Writing directly to an I/O port is not allowed for security
reasons. There are VI's to do the required system calls.
You might be able to use the (old) serial VI's with a high serial port
number. You can look up the port number on a LV version for Windows.
I'd use a completely different strategy: VISA can address parallel
ports. With Windows you just use ASRL10. You might need some tweaking
of the VISA preferences files to do it.
Printing data to a parallel
port should be done with the tools
designed for it: System Exec: lpr file.txt
Does someone have a summary of the options for reading the parallel
port and setting control lines via the described methods?
Johannes Nieß
(4,087 Views)
maybe i didn't comunicate here.
i don't intend to print anything out but i want to set each pin of the port
hi or low. i'm trying to turn some electrical relay-switches on and off.
thanks anyway, all these hints are useful to me
"Johannes Niess" wrote in message
news:m2u2b1556o.fsf@server.landtechnik.uni-bonn.de...
set
> Michael,
> Printing data to a parallel port should be done with the tools
> Johannes Nieß
(4,087 Views)
Michael,
So using an true ASCII printer or dircetly /dev/lpx is the easiest
solution. Just "print" the ASCII charakter representing the bits to
set.
Johannes Nieß
> set
> > Michael,
> > Johannes Nieß
(4,087 Views)
maybe you could use the shell vi in LabVIEW for Linux or the pipe vi to send
your data to the lp device ?
"michael h. fischer" wrote in message
news:8qquih$3l3u$1@www.univie.ac.at...
> best of regards
> michael h. fischer
> icq: #61578912
> vienna university
(4,087 Views)
