Calling LabView dlls from VB
I am using the .net environment and this NI e xample...
http://zone.ni.com/devzone/cda/epd/p/id/3990
which is just a simple dll that outputs some numbers.
I get the following error
Attempting managed execution inside OS Loader lock. Do not attempt to
run managed code inside a DllMain or image initialization function
since doing so can cause the application to hang.
and it crashes! Any suggestions?
(3,117 Views)
Different user name but same question as here?
(3,086 Views)
This issue is addressed in the forum linked by Ravens Fan.
Donovan
(3,070 Views)
