the panel as image
hey guys, i need to capture a chart graph which is on the front panel (quite big screen!)
p.s:it should capture the image each time i run my program and it should have very good quality, it should be saved in a specific location with a specific name.
any suggestions?
thanks alot
(3,366 Views)
See this link,
http://forums.ni.com/ni/board/message?board.id=170&message.id=280903#M280903
Software developer
www.mcm-electronics.com
PORTUGAL
(3,361 Views)
Also, try looking at this. It includes a set of VIs you can use.
___________________
Try to take over the world!
(3,352 Views)
thnx for the given link , but my code has to capture the picture right after the program runs.
this code looks like that we have to press capture ourselfs
greets
(3,341 Views)
then take a look at the first link in the first reply, which does exactly what you want.
Jeff
Using Labview 7 Express
(3,334 Views)
You can use the same VIs that program uses - they are found in the user libraries palette after you install it and restart LabVIEW.
___________________
(3,319 Views)
