Calling Labview through C++ for Labview 8
I found this example code (http://sine.ni.com/devzone/cda/epd/p/id/858#0requirements) to acquire data using C++ code via Labview and was wondering if there are any changes I need to know about using it with Labview 8.5.1.  I am using the DAQ board USB-6225.  Thanks a lot.
(4,110 Views)
Hi there
Yes, you can. Attached is the modified example from http://sine.ni.com/devzone/cda/epd/p/id/858#0requirements, compiled with MS Developer Studio 6 and LabVIEW 8.5.1. You need to make slight changes. See the LabVIEW help for details about the LabVIEW ActiveX interface (see LV_Help.JPG in the attached archive).
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,095 Views)
Thank you so much!  It is working.  I am using Visual Studio 2005 and did have to take out the lpctstr function at this line: pVI = pLV->GetVIReference((Path),(Password), false, 1); or else I got a runtime error, but other than that, it seems to be working great.  Now I just have to figure out how to program it to work with my custom VI.  That will be fun :).  Thanks again for your help.
(4,074 Views)
One additional question about this.  How do I know the data structures within the Labview so that I can access actual sample values from this waveform?  I have accessed other simple variables like, # of samples and can create an indicator that lists the values in a column called Y but I cannot figure out how to call them in my C++ program.  I would guess there is an array like "waveform out.y.0" for the first sample or something but I can't find any reference on that.  Thanks for any help!!
(4,061 Views)
Hi there
i don't know about the internal structure of waveforms, but i would not expect that any LabVIEW datatype is passed in a comprehensible way by COM/ActiveX. Use a common data structure like arrays instead.
You may want to use the debugger functionality of VC to see the data structure inside the C++ variant data.
Also take a look at the LabVIEW Help sections
Fundamentals->Calling Code written in Text-based Programming Languages
Fundamentals->Windows Connectivity
Fundamentals->How LabVIEW stores Data in Memory
Best regards
chris
(4,049 Views)
It is typically much easier to use a common data structure like chrisger says. The LabVIEW Help sections that chrisger recommended are also good resources. Also, you can use a Get Waveform Components function to break apart a waveform and get the array of amplitude values from it.
If you have Application Builder, you can convert your VI to a DLL, and call it via C++ that way. See the link below for more information calling a LabVIEW DLL.
http://digital.ni.com/public.nsf/allkb/70995EC2CA1B523386256DD4004F3DE6?OpenDocument
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(4,041 Views)
