Calling Python Function in LabVIEW
I have a function written in Python that I would like to use in real time in LabVIEW. The function requires a few inputs, which LabVIEW is receiving through a DAQ system. Is it possible to call that Python function in LabVIEW, giving it inputs and receiving output data in real time?
Essentially the VI is acquiring pressure and weight data and the function uses pressure and weight to calculate different masses, and I would like to output those masses on the front panel in real time if possible.
Thanks!
(4,853 Views)
(4,814 Views)
"The Python Node is not supported on real-time or FPGA targets."
If you by real time mean in a running LV program, it can work, if you mean on a RT target, then no.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,803 Views)
/Y
Good point, I got a PC vibe from the "using DAQ system" remark.
On a RT target that support Linux, I guess the command line is still an option? Not sure how that would work with passing parameters. Probably not the most efficient thing to do...
(4,793 Views)
