In general, having the VI open its front panel shouldn't cause any problems. I just tried it out on my Windows 2000 machine and it worked fine. I started with the example "Using Microsoft Visual Basic to Call LabVIEW DLLs That Pass Numeric Data Types" off of NIs website. I then modified the VI so that it called a subVI to show its front panel. I then rebuilt the dll and called it from Visual Basic. The front panel appeared fine and didn't crash.
Some things to note/watch out for:
1. When I defined my prototype I used standard calling convention.
2. The subVI contains a property node to show the front panel.
3. In the build script on the VI Settings tab, the subVI was configured so its front panel was not removed.
I have attached the parts of
the example that I modified for your review.
