Calling and using LabVIEW VI's in a C# application : user manual ?
Hi everyone,
I am working on a project (actually a proof of concept) where I need to call and use LabVIEW VI's in a C# application.
I downloaded the example available on this page : Calling LabVIEW VIs from Other Programming Languages.
This example (joined) is working fine, but I would like to know if there is an associated documentation concerning the .NET classes that I can use in C# when I use the namespace "LabVIEW" (using LabVIEW; in C#).
I need to know a little more about the properties and methods that are available (what it does and how to use it).
I looked for it on NI's website and the LabVIEW help but could not manage to find anything interesting.
Is there an official documentation released ? How can I get those informations ?
Thanks for your answer(s).
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
Message 1 of 12
(10,372 Views)
That specific example is calling LabVIEW from C# using ActiveX. Is this what you are specifically trying to do, or are you intending to create a .NET Interop Assembly from the LabVIEW code? Those are two fundamentally different approaches.
Message 2 of 12
(10,362 Views)
Hi smercurio_fc,
I want to call LabVIEW using ActiveX in C#, this is what the example is doing.
But I couldn't find any informations about the methods and properties available from the ActiveX (if I want to use the other methods available and not only the one included in this example).
Do you have any idea where I can get those informations ?
Da Helmut
Message 3 of 12
(10,357 Views)
You must not have used LabVIEW very much. Simplest is to select VIEW>Class Browser.
Message 4 of 12
(10,352 Views)
The class browser is usefull (ctrl + shift + b), but I am not developing the C# application on the same computer than the LabVIEW application.
The *.chm file has all the informations in it but I am not finding it well organized. I am drowning in all the informations. I supposed there was a specific help file / manual for the ActiveX methods and properties (a kind of hierarchical view like in the class browser).
Also I supposed that there were different methods and properties that the one available in LabVIEW.
For example when I browse the class in C# I get those weird methods :
Da Helmut
Message 5 of 12
(10,344 Views)
The properties and methods are all documented in the LabVIEW Help. Fundamentals -> Windows Connectivity -> How-To -> ActiveX -> Properties and Methods. For the labviewApp variable in your example you'd be looking at the "Application" subchapter. Any of the methods/properties that start with "_" are undocumented and should not be used.
Message 6 of 12
(10,334 Views)
Hello Team ,
My requirement is to control VI from C# application  and i got the link to  https://download.ni.com/pub/gdc/tut/callinglvcsharpusingactivex.zip.
The dll available in this project is Assembly Interop.LabVIEW which is serving my purpose but as several seeker asked before what is the systematic way of learning  and achieving knowledge to control VI panel from a C# project?
Where can i get complete  information on   the  Assembly Interop.LabVIEW ?
Thanks in advance for your time and knowledge!
Thanks and Regards,
Chetan
Message 7 of 12
(4,793 Views)
National.Instruments.LabVIEW.Interop.dll as the name already says is an Interop assembly. It uses some Windows API calls and many private LabVIEW APIs to do its things for various .Net tools that NI distributes but it is not really meant for customer use and hence not officially documented.
This means you can try to use it but there is no guarantee that what you found out will exist in a newer LabVIEW version, or work in the same way, or not have suddenly a bug since it is a method that NI doesn't use anymore and therefore doesn't test.
The only officially supported ways to call LabVIEW methods from a .Net application are:
- Through the LabVIEW ActiveX Automation interface
- Creating a .Net assembly in LabVIEW from your code and calling it from your application
The example provided in your link uses the first method by referencing the LabVIEW Active X Type Library. Visual Studio then helpfully creates an interop library for you to translate between your .Net application and the ActiveX interface for LabVIEW. The documentation of this ActiveX interface is in the LabVIEW online help under Contents->Property and Method Reference->ActiveX.
As already mentioned this is a rather small subset of the actual LabVIEW VI Server interface but that is all that you can use without going into creating your own C# Interop vodoo by hand to directly call into LabVIEW kernel exported functionality.
Rolf Kalbermatter  My Blog
Message 8 of 12
(4,769 Views)
Thanks a lot for such a nice description ,this information helped me a lot!
I went through the Information available in the help documents on "ActiveX" ,I studied methods, properties ,enums ,object names   etc. available for the user to access kernel exported features   but i failed to  figure out  the file path or name of library/dll to be linked before I start writing my own C# interop to access LabVIEW kernel . Could you please share some knowledge on file information  to directly call into LabVIEW kernel exported functionality.
Would  C:\program files (x86)\national instruments\shared\labview run-ime\XXXX\NationalInstruments.LabVIEW.Interop.dll  be the right dll to be used to access functionality and methods mentioned in help document ?
Thanks again for your support!
Thanks and Regards,
Chetan
Message 9 of 12
(4,733 Views)
No that is not the right thing. That is the library I mentioned in the beginning. It is private and undocumented.
The project in the example specifies the LabVIEW Active X interface by its GUID {9A872073-0A06-11D1-90B7-00A024CE2744} which tells Visual Studio to look in the registry for the actual interface definition. When you look that up in the registry you will see a reference to a LabVIEW Type Library.
It's path is registered to be C:\Program Files (x86)\National Instruments\LabVIEW <version>\resource\labview.tlb
This Type Library is a resource that describes the ActiveX interface and where to find its server (usually the LabVIEW.exe file).
This server is then instantiated through Microsoft COM, the technology on which ActiveX is built. Visual Studio automatically generates an Interop assembly resource to translate between a .Net interface that you can directly call from your C# code and the ActiveX Automation Server interface that LabVIEW provides and which also takes care about instantiating the necessary ActiveX Automation Server.
You should be able to add a reference to an ActiveX Automation Server in your Visual Studio project without the need to specify a GUID or a direct path to some Type Library by somewhere adding a project reference that lets you browse all currently registered ActiveX Automation Servers on your system by their name. Although there is the possibility that recent Visual Studio versions have made that less than trivial to do. Microsoft actively tries to get away from ActiveX and discourages its use as much as possible, to eventually remove it as a supported technology sometimes in the not so near future.
Message 10 of 12
(4,720 Views)
