Calling "glutInit" cause LabVIEW crash
Accepted by topic author brano.s
It has been awhile since I have used GLUT, but I think that glutInit should only be called once per process.  When you run a VI, we don't start a new process.  My guess then is that glut fails due to the duplicate call
I have confirmed this experimentally.  If I guard my call to glutInit such that I only call it once per process, things seem to be much better.  This can be accomplished by a simple static in your dll.
Example:
	static bool first = true;
	int argc = 0;
	char* argv[] = {"foo"};
	if(first)
		glutInit(&argc, argv);
	first = false;
Quick question: why aren't you using the 3d picture API instead?  We have full support for having either an embedded control or a stand alone window to render your scene into.  I would be very interested to hear why you chose to interface with GLUT as opposed to a LabVIEW only solution.
Message 11 of 13
(1,051 Views)
Thanks for reply and solution! Works just fine.
To your question:
I am using CUDA in LabVIEW and since calculation result (hologram) computed by CUDA is stored on GPU I decided to use CUDA/OpenGL interface to directly display hologram (now it is not neccessary to copy hologram back to labview which send it back to GPU to display it).
I am not very familiar with OpenGL so I decided that the simplest way how to make my first CUDA/OpenGL/LabVIEW program is to modificate example from here. I did not expect this problem and second reason is that I did not know about 3d picture API.
Is there some nice tutorial for 3d picture API?
Message 12 of 13
(1,040 Views)
brano.s wrote: [...]
Look at the LabVIEW Help: Search for "Using the 3D Picture Control".
LabVIEW also comes with examples for this control. In the example finder, search for "3d picture".
Message 13 of 13
(1,029 Views)
