Can BACnet points be written or read with Labview?
Did you try clicking the link in the post above yours?
Message 11 of 14
(1,424 Views)
Dear all, take a look at the recent updates related BACnet protocol in LabVIEW tools network
BACnet MS/TP Protocol for LabVIEW by Ovak Technologies
The BACnet MS/TP Protocol for LabVIEW is a set of VIs that enable NI equipment to work as slave devices in building control systems.
Implemented based on LabVIEW object-oriented programming, BACnet objects offer the advantages of code reuse, encapsulation, and maintenance. You can use the toolkit on NI real-time hardware targets such as CompactRIO, Single-Board RIO, and PXI. You can also use it on Windows-based computers.
  • Integrate NI hardware into the BACnet network without OPC servers
  • Use BACnet system's testing with the benefits of NI technologies
  • Add specific objects to the system on demand
  • Runs on both real-time and host targets
Link: https://www.ni.com/en-us/shop/product/bacnet-ms-tp-protocol-for-labview.html
BACnet/IP Protocol for LabVIEW by Ovak Technologies
The BACnet/IP protocol defines a standard way to communicate over a number of wires known as data link/physical layers. It also defines a standard way to communicate using UDP as a virtual link layer.
The BACnet/IP for LabVIEW toolkit is a library that you can use to browse BACnet devices, read and write properties, and perform other tasks specified in the BACnet standard.
  • No OPC server required
  • Direct communication with peer devices on their networks
  • Use of local, remote, and global broadcasts
  • Communication between BACnet devices and NI hardware/LabVIEW
  • Dynamic creation of protocol objects
Link: https://www.ni.com/en-us/shop/product/bacnet-ip-protocol.html
Message 12 of 14
(1,396 Views)
Please find the video on below link for BACnet in LabVIEW
LabVIEW performing BACnet object Writing
Message 13 of 14
(1,214 Views)
Please find BACnet object reading on below link.
LabVIEW performing BACnet object reading
Message 14 of 14
(1,213 Views)
