Can Boolean text direction be changed? Labview 8
Is it possible to set the text direction for the text in a Boolean control? The properties for Booleans includes vertical arrangement for Boolean Text. When I try to set this property (to any of the available options) I get Error 1054 (the specified object was not found). It lets me set the text direction for the label just fine, but that's not what I want.
George
(4,509 Views)
Whoops, this looks like a bug. :(
(4,506 Views)
Looks like a bug to me too. Rats, I sure could use this function.
(4,505 Views)
Hello GS,
I filed a report on this behavior to the development team for further investigation.  Thanks for the feedback!
Wendy L
LabWindows/CVI Developer Newsletter
(4,472 Views)
This was reported to R&D (# 3TP02RD1) and was fixed in LabVIEW 8.2. Note, our documentation states that this only works for labels, captions, and free labels.  So, we now return a more descriptive error code:
"Error 1453 ...
Possible reason(s):
LabVIEW:  You may only set the vertical arrangement on a label, caption or free label."
I hope this helps,
Travis H.
LabVIEW R&D
(4,323 Views)
