bug typedef does not connect to expression node
Attached is a simple vi that tries to connect a typedef (in this case a double) to an expression node.
Since LV8 this is not allowed anymore.
We choose LabVIEW because it was possible to use it as a strict typed language. (one of the reasons).
We see that the developers go a long way to make the language so easy that it is too strict to allow typedefinitions to an expression node.
But it can also be a slip of the compiler of course.
attached are the example vi and the typedef.
please supply a patch because this makes it impossible for us to switch to LV8
greetings from the Netherlands
Albert Geven
(4,555 Views)
A workaround is easy but should not be necessary because the typedef is used to keep it a typedef.
Simply use an explicit type conversion in this case to [DBL], at least that was my guess....
but an explicit conversion already knows there is nothing to do so it does not help.
A typecast helps but sure that is not what I want, see picture below.
(4,517 Views)
Sorry for the inconvenience, I have filed a bug report on this issue.
(4,488 Views)
While waiting for the bug to be fixed, you can do something like I've illustrated in the attached screenshot.  Sure, it's ugly, but it will work.
(4,465 Views)
Thanks Stephen and Jeff.
I already found out the typecast myself and I also blame myself for not finding it in the beta.
I can use this workaround but sure its ugly and not what you want for a typedef
(4,449 Views)
This was reported to R&D (# 3TU9381W) and was fixed in LabVIEW 8.0.1.
Thanks!
Travis H.
LabVIEW R&D
(4,300 Views)
