Can Case Structures execute one particular set of code for multiple conditions?
Event Structures can have a single Event case handle multiple Event Specifiers.
C code supports this kind of 'switch' statement:
switch(enumValue)
case A:
case B:
    handleAOrB();
    break;
case C:
case D:
case E:
    handleCOrDOrE();
    break;
default:
    handleOther();
How about Case Structures? Can I attach one code block to multiple enums values? (without duplicating the cases, which could be a maintenance nightmare)
Edit: The closest thing I found is http://forums.ni.com/t5/LabVIEW/case-structure-multiple-inputs/td-p/2377132, but converting my original enum into another one is somewhat unappealing
Certified LabVIEW Developer
(3,111 Views)
Accepted by JKSH
You can specify multiple enum values for an individual case. Is this what you were looking for?
For more information, check out the series of weekly nuggets I wrote on Case Structures: Part 1, Part 2, Part 3, Part 4, and Part 5.
(3,101 Views)
That's exactly what I was looking for! Your Part 2 nugget held the key: I have to type in the comma-separated list manually. I was looking in the right-click menu but couldn't find anything, unlike with the Event Structure.
Thank you very much!
(3,079 Views)
You can also enter a range with double dot, as 1..5
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,062 Views)
