Can I Bind a Front Panel LED to a specific element in an array of booleans?
Accepted by topic author dbaechtel
No.  You don't have to do a whole bunch of individual wiring.  You can create an array of references to your LED's and pass that array into a For Loop along with the array you read from the shared variable.  Autoindex with both arrays on the For Loop and write the boolean value to a value property node.
There is a right click framework that makes wiring the array of boolean references easier.
Message 11 of 11
(439 Views)
