02-09-2012 10:38 AM
I would like to know how to programmatically change the active group of a hypertrend in Labview DSC. I saw a link which said it can be done in Lookout. But in the DSC module, the active group is read only.
I know of a hard way to do it. I could save the hypertrend settings as xmlSettings to a temporary file. The active group is one of the settings. I could then change the active group in this text file to point to the new group and then reload the settings. But this is not a clean way of dong it.
Anyone know if there is a easy way?
Solved! Go to Solution.
02-09-2012 03:08 PM
I found a way to do it but its not very clean. I dont know why there is not a function to change the current group.
Here is how I did it.
