Can I Use labview to snap my mouse to the left edge of the screen at the start of my program?
I'm trying to get it so when my VI starts it instantly snaps the curor to the left edge of the screen but then allows cursor movement after this. Is there a way to get LabView to do this?
"There will be water if God wills it"
(2,505 Views)
Accepted by Nproach
Hi Nproach
Try using this community example.  It calls the User32.dll library and takes advantage of the SetCursorPos function.
Peter D
(2,500 Views)
Thank you for that, it helped quite a bit
(2,487 Views)
