Can I call a regular LabVIEW VI from my C# application without first creating a DLL in the application builder?
I am writing a C# application and have LabVIEW 8.2 and the Application Builder. I want the application to call different standard VIs included in LabVIEW. One way to solve this is to create a blank VI, insert the desired standard VI, have the Application Builder create a DLL and then let the application call the DLL. Something tells me there must be a shortcut to this, is there? Aren't all standard LabVIEW VIs really DLLs underneath the surface? Can I somehow call those DLLs directly?
(2,599 Views)
NO, LabVIEW is a programming language and contains a lot of primitives. Some VIs are wrappers for DLL's but even calling these from C(#) might be a problem.
You can exploit the LabVIEW ActiveX interface to perform all the actions you want.
Ton
My LabVIEW Ideas
(2,598 Views)
