Strange textfiles created
Hello
These days, I am experiencing a strange behaviour from my textfile writing function in my Labview application...
Instead of creating the desired textfile with the good characters, Labview registers on the harddrive a big text file with the same string, always repeating itself. In the past, the function had worked properly.
I guess it is a problem of memory... What do you think? How can I check this?
Thanks for your help.
(2,800 Views)
Without any code this is very hard to guess.
Could you attach a VI or an image of the code?
Ton
My LabVIEW Ideas
(2,799 Views)
Hi Ton
Attached: my vi!
Hope it will help...
(2,793 Views)
