Can I change the orientation of an XY Graph?
I'm using an XY graph to plot two dimentional hand locations with in a square. The sensors I am using are at the four corners of the square thus not on the XY planes. I am wondering if there is a way to rotate the XY Graph say 45 degrees?
I hope the answer is yes as it's the simple solution! ( I know it's probably not that easy )
(2,514 Views)
Try the 2d Cartesian Coordinate Rotation VI.  Look on the palette under Mathematics -> Geometry.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,502 Views)
