usrp 2920 minimum detectable signal??
Hallo to everybody !!! it's only a month that I'm using the NI USRP 2920.
I have a question  please
I want to Know minimum detectable signal for the two port TX1/RX1 and RX2.
thank you
Francesco
(4,394 Views)
Hi Francesco,
you can check these information on USRP data sheet:
http://sine.ni.com/ds/app/doc/p/id/ds-355/lang/en
In particular the minimum detectable signal depends on frequency.
Giuseppe.
(4,378 Views)
thank you Giuseppe
are you italian?
(4,374 Views)
Yes Smiley Happy
(4,372 Views)
allora approfitto e scrivo in italiano...
sto cercando di progettare un sistema SDRadar utilizzando la USRP 2920 ..
spero di riuscire a superare i limiti legati all'interfaccia USB della USRP di prima generazione della ETTUS.
ho guardato il datasheet( http://sine.ni.com/ds/app/doc/p/id/ds-355/lang/en ) e alla voce receiver trovo :
Max Input Power (Pin)  0dBm
posso fidarami di questo parametro ?non mi sembra legato alla sensibilitĂ  del ricevitore (mi aspettavo un "Min imput power")
Saluti Francesco
(4,366 Views)
Accepted by topic author jtudor
Hi giuseppe I measure the sensibility of the USRP ..
it's around <-130 dB
by
(4,349 Views)
Hello All,
I want to calcalute the noise floor of the USRP2. Any help in this regard will be greatly aprreciated .
Regards
(4,309 Views)
