Can I change the voltage range of an analog input (FP-AI-102 Input Module) in LabView?
in my application I use a FieldPoint AI-102 analog input module which is controlled by LabView. Is it possible to change the voltage range of the inputs in Labview or can I only change them in the "Measurement and Automation Explorer"?
Thanks.
Michi M.
(2,678 Views)
Look at the high and low limit controls at the analog input functions. You can recieve help using 'cntrl + H'
(2,678 Views)
