visa resource name
My program requires the serial port configuration to be setup be a *.ini file, eg one parameter in the config file will be serial_port = . Representing the computer serial ports and can be changed to any port without rebuilding the software or having the user to select at run time. Can someone please explain how I can convert a uint32 to a visa resource name - if this is possible?.
Thanks Wayne
(3,333 Views)
I will answer this my self...I have used (with minor modification) a VI found at http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000376D0000&UCATEGORY_0=_50_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_TIER_0=0&USEARCHCONTEXT_TIER_S=0&USEARCHCONTEXT_QUESTION_0=visa+platform+independant&USEARCHCONTEXT_QUESTION_S=0.
Wayne
(3,333 Views)
Self answered Q's are the best!
We know they are the correct answer.
Ben
(3,333 Views)
