Can I change the waveform graph palette to be viewed by default?
When I create a new waveform graph I would like to automatically have the graph palette displayed instead of having to change it manually each time. The same goes for some other features of the graph but the palette I believe is probably the most frustrating to manually set every time.
(2,479 Views)
Hi Jimbo,
The easiest thing I can think of would be to save a Waveform Graph with the graph palette showing as a custom control (.ctl) in the user.lib folder.  After you restart LabVIEW, you should see that .ctl in the "User Controls" palette on the front panel.
Hope this helps,
-D
(2,474 Views)
