Controlling a chemical process with LabVIEW and the SC 2075 board
I am a degree student and one of my projects is to control a chemical process using LabVIEW and the SC2075 board. The process variables i must control are temperature, pH and also several motor. Is this viable using the SC 2075 board and if so does anyone know where i can attain information on using the board. Also if anyone has suitable sample vi's that may be of use to me it would be very much appreciated. My email is x00010372@itnet.ie
Kind Regards,
Derek
(3,208 Views)
Hi Derek,
Bellow is a link the the user guide for the 2075.
http://www.ni.com/pdf/manuals/371217a.pdf
You should be able to aquire data from you sensors but you might need some signal conditioning depening on the voltage levels they return.
For sample vi's try going to Help>>Find Examples... within LabVIEW or goto the following link to search our developer exachange.
http://www.ni.com/devzone/dev_exchange/ex_search.htm
For more information about Signal conditioning and Data Aquisition try:
http://zone.ni.com/devzone/devzone.nsf/webcategories/4d58b1b80ec41ef70625683f006e1d6d
I hope this helps
Regards
Jon Bowers
NIUK
(3,194 Views)
