Can I communicate HP34970A with Labview 5.0
I want to control and communicate a data scanner (34970a) with my Labview for windows that I have been using for some time. From the NI website, I find a Labview driver for this instrument. In the driver's download page, I read that the minimum version of Labview that can use with the driver is 5.1.
The version of my Labview is 5.0.1, lower than the minimum version specified in the download page. Can I run the instrument drivers and communicate with the instrument successfully with my Labview 5.0.1 without upgrading it?
Please help.
(2,932 Views)
I downloaded the 5.0 drivers a couple of years ago, and hope NI won't end giving them, but if you want, i can dig those drivers out for you, i know they're somewhere in my computer, as long as i worked with a HP34970A data logger some time ago.
Good luck
(2,932 Views)
That would be great if you can send me a copy of the 5.0 drivers for 34970A.
Thanks a lot!
If you want to send it to me directly, please send it to the following email address
rogchan@clp.com.hk
Thanks very much!
(2,932 Views)
I'm not able to attach the file to this comment, i'll try to send it directly (1,7 Mb).
(2,932 Views)
Hi Gorka, it seems that I have the same problem - have downloaded the newest ni drivers for hp34970A data logger - but owning only a labview 5 software. Could you be so kind (again) sending me the "old" 5.0 drivers??? Thanx in advance: Holger
(2,932 Views)
(2,932 Views)
