Can I continuous update a waveform in a 6713 Card? I need to inc and dec the frequency continuously without stoping the generation. Can I do so? how?
Hi.
I`m using labview 7 and a analog output board, the 6713. I`m building a system that generates sine wave forms and I need to change the frequency of the generated waveform without stoping the generation. Can I do so? And how?
Thanks.
Ismail.
(2,650 Views)
You can invoke the "AO Clock Config" VI after invoking the "AO Start" VI to change the update rate without stopping the generation. The "Function Generator" example does exactly this.
Geoff Schmit
Huskie Robotics, FIRST Team 3061 Lead Mentor
http://team3061.org/
@team3061
(2,650 Views)
