Can I control one line from serial VIs.
Hi! All,
My application is developed for RS 232 communicaiton. Now I would like
to add the RS-485 also to it.I am using LV 7.1.
I would like to control one of the lines( any one from DSR, CTS or
RTS) which will send a bit to indicate that it is either a
transmission or receiving bit. After few msec I should be able to send
the actual data or read the actual data.
How can I achieve this using LV serial VIS?
TIA,
Rachana
(2,898 Views)
The only pin that is an output from the pc is RTS. To set this line or to read the state of the other lines, you use a VISA porperty node. Select the property Modem Line Settings.
(2,898 Views)
Dennis Knutson wrote in message news:<5065000000050000005FB60100-1079395200000@exchange.ni.com>...
Hi! Dennis,
Thanks for the help. I forgot to mention that I am developing the
application for the PDA. Property nodes are not supported on PDA. Is
there any other way to achive this?
For Windows, as you mentioned that I could use the property node, is
there any start up document or example for this? I would like to know
if it is also possible to transmitt data on the Pin 2 and 3, depending
upon if RTS is high bit or low.
TIA,
Rachana
(2,898 Views)
I'm not familiar with the features of the PDA so I don't if there's an alternative. Are you trying to implement your own hardware handshaking because the device or the PDA doesn't support this?
(2,898 Views)
