Why would my data collection stop when I make the VI an executable?
I collect data, and save it to a data directory. In full developement mode, the data collection works fine, but when I build an executable from the original vi it no longer stores the data.
(2,302 Views)
How are you determining the path to the location for storing the data? Any paths that are determined based on the current location of a VI must take into account that the path to a VI is different when built into an executable. If you are doing a strip path, then you need to do one more in an executable. In the development mode, the path to a VI might be c:\junk\example.vi. In an executable, the path to the same VI will be c:\junk\junk.exe\junk.vi.
(2,302 Views)
