Can I create a Table with Boolean-Buttons
I want to create a table (or listbox) with "OK-buttons" because the number of rows are unknown and i want to have a scrollbar. So i had the idea to create a table with visible Row Headers in which i write a description and in the first row i want to have "OK-Buttons"
I think i can't create an array on the Front Panel with a scrollbar. So it is possible to read out an array of boolean from a table or can i do this only with strings?
Kind regards
Bastian
(7,480 Views)
Hi
how about a multi list box with a checkbox. i used a event structure to signal a check on the row.
(7,472 Views)
In reply #22 of this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=127096
I posted an example that uses an array of clusters to do something similar.
That technique takes some customizing of the controls but requires no coode to implement.
It looks like this
Ben
Message Edited by Ben on 10-29-2005 10:25 AM
(7,457 Views)
Thank you for the answers,
I prever the solution with the array and the slid from ben.
Bastian
Message Edited by Bastian on 11-01-2005 03:23 AM
(7,420 Views)
