Can I create a sw device with LV to check the output of my UUT's parallel port?
My unit under test has a parallel port that is used to print to an external printer.
Is there a way with LabView that I can connect my UUT to the PC's parallel port and verify the output from my UUT?
Thanks!
(2,768 Views)
Yes. You can connect your device to parallel port of PC and can communicate with it using the Port I/O VIs located in functions>>Advanced>>Port I/O
(2,761 Views)
Yes, you need a special cable. It was used in the past to share data between two PCs. Didn't the good ol' DOS Norton Commander supported that ? Smiley Happy
I did something similar in the past to connect an old standalone test unit with protocol printer to a SPC database. Since the amount of data wasn't big and cable lenght and ground loops where additional tasks, i used a galvanic isolated parallel to serial (RS232) adaptor. That way I could use the VISA driver and didn't have to care for access right to use the PORT I/O vis. You also should try to use the VISA vis to read the parallel port directly.
Greetings from Germany
Henrik
LV since v3.1
(2,755 Views)
Hey Guys, thanks a lot for your suggestions.
Seems like I can set up my parallel port to read by flipping the 5th bit on the Control register. However, I'm not sure I have the right cable for the job. I tried using a direct P1-P1, P2-P2.... as well as a Windows "Direct Cable".
When I connect my device to the computer, the device thinks the printer's Busy; I tried flipping the busy bit (bit 7 on status refister), but this had no effect; this is why I think I may not be using the right cable.
Any suggestions?
Thanks!
(2,715 Views)
