Create custom function f(x) for determing values of Y.
Hello. I have a question. I have a set of data which I measured against varying voltage.
Because the measured voltage is high, so it is scaled down before being measued by PC.
When the actual readings are read on Labview, so they have to be scaled up mathematically to correct readings.
The  scale factor is same for both "In" and "out" However the readings are not correct.
The scaled down readings do not mirror as those on the PC before scaling up.
I know it has nothing to do with the my labview program's working because it is getting raw data before measuring vi function using ac mode.
It has to do with the manufacturer's card, not NI card.
So I thought of using the function equation to set the correct readings.
The x values from the raw data by labview which is not correct, are used to give actual readings.
 For eg:
High voltage Actual readings (scaled down readings)
(2,463 Views)
This post is a duplicate.  Please follow this forum here.
Thanks!
Travis M
LabVIEW R&D
(2,451 Views)
