Can I do this Solidworks simulation with the SoftMotion module?
I searching for a way to simulate a motor control loop on a SolidWorks model.
All I would need is some position feedback from the Solidworks model into labVIEW, and motor force control from labVIEW to Solidworks.
Is that possible?
I know that you can define postions in Solidwork that would trigger something in labVIEW. But I would need a variable that indicates the postion of some moving part (e.g. the position between two predefined points). I also know that you can define motion profiles using labVIEW. But I would need the possibility to control the force that a motor is generating (or torque). Or alternatively controlling the force on some lineair moving part.
Note that I posted an equivalent question on this labVIEW forum but on the wrong board. The hardware motion board. And I'm talking about a complete software simulation. Sorry for this.
(2,605 Views)
Dear Melomania,
Please find here  here  the getting started guide for NI softmotion and solid works,
Martijn S
NI Netherlands
(2,583 Views)
Thanks for the information.
Unfortunately it is still not clear to me.
Is the block diagram in figure 6 fixed? Or can I use my own control configuration?
In this diagram there is an encoder feedback. But I can not find any information in the document how this relates to the SolidWorks model.
Is this feedback really possible?
(2,574 Views)
