Can I use Citadel as database in cRIO(having VXworks)
Is it possible to have citadel as database in cRIO having Vxworks as OS.
I donot have any host pc in the developement setup.
I need to store data in cRIO by implementing any kind of data.
Kindly let me know what all are the drawback for citadel.
(2,752 Views)
Citadel works only on PC Machines with windows OS. If you want log data in cRIO you must use file functions located on File I/O palette. And if I not wrong all the TDMS, ZIP, Storage VI, XML palettes dont will work too.
(2,734 Views)
There is an SQLite library somewhere on one of the NI Developer Resources specifically ported to cRIO. That may be the solution for you.
Rolf Kalbermatter  My Blog
(2,694 Views)
