Can I get a 'timetable' of what labview does when it runs the program?
Can I get a 'timetable' of what labview does when it runs the program? i.e. how long it spends doing each sub vi, and what order it does them in.
Cheers
Message 1 of 13
(4,267 Views)
Yes you can Smiley Happy
Use Tools\Profile\Performance and Memory from the front panel menu.
Message 2 of 13
(4,262 Views)
Im trying to use it, but it says everything takes 0 microseconds, what am I doing wrong?
Message 3 of 13
(4,254 Views)
Here it an article about how to use it:
http://zone.ni.com/reference/en-XX/help/371361E-01/lvhowto/profiling_vis/
Regards
MY
Message 4 of 13
(4,251 Views)
Is there a way to find out what order the program performs sub functions?
Cheers
Message 5 of 13
(4,225 Views)
Im trying to find out if the time at which data is read from hardware, is the same as the time given by the get date time vi, when it is written to a file, the data and times are matched up.
Message 6 of 13
(4,223 Views)
The Trace Execution Toolkit will do that.
You could also use NI Spy to log the serial traffic.
Ben
Message 7 of 13
(4,214 Views)
where can I find those tools?
Message 8 of 13
(4,203 Views)
Accepted by ssteel
Execution Trace Tool kit is an add-on. If you don't have it your pack of disks, ... maybe try a demo version?
NI Spy get loaded with LV (or one of those things).
Start >>> Programs >>> National intruments >>> NI Spy ?
Ben
Message 9 of 13
(4,200 Views)
How do I use NI Spy to get the time taken for each sub vi and the order it does them in?Iv tried running the program whilst the ni spy is open, but i dont under stand the results?
Cheers
Message 10 of 13
(4,174 Views)
