Can I include raw files into the installer folder with LV application builder?
I have created a batch file that will run at the end of the installer, which will copy over some raw configuration files into the source destination so that the configuration files can be customized for each end user without rebuilding the installer with application builder. I also have an autorun.inf so the installer will automatically run when the user installs the CD.
However I would like to have some default configuration files and an autorun.inf file that will be automatically added to the installer "volume" folder using the application builder.
However I don't see a way to include raw files in the "volume" folder. It appears all source files in the application builder are embedded into the binary files.
Please let me know if this is possible with the current application builder.
Russell
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
(2,584 Views)
Russel,
i think this link might give you some good hints....
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,577 Views)
