Error using Mathscript function: interp2
Is the Mathscript function "interp2" with the usage: z = interp2(x,times) supposed to work only if x is square matrix?
I tried  (in Labview version 8.6)
>>interp2(rand(5,4),2)
ans =
          empty matrix 0 by 0
and get the empty matrix. The help does not suggest it must be square.
(3,102 Views)
Hi Uwaj,
Thank you for bringing this to our attention. This behavior has already been documented and fixed in version 8.6.1 in Labview. You can see it here:
LabVIEW 8.6.1 Bug Fixes
Under ID number 125525. If you are seeing problems with this behavior in 8.6.1, please let me know.
Claire Reid
(3,083 Views)
