Can I install 8.5.1 modules on a LABVIEW 8.5 system
Can I install 8.5.1 modules especially ARM module on a LABVIEW 8.5 system ...
Since 8.5.1 is just a minor upgrade to 8.5 I guess it should do ..
But does it work effectively while importing code to  ARM processor
(2,624 Views)
Hi Bharath,
No, it's not a good ideal to install an 8.5.1 module on LabVIEW 8.5.  It may function, but chances are that it won't.  The versions should match exactly.
You will want to upgrade your LabVIEW to 8.5.1 before installed the LabVIEW Embedded Module for ARM Microcontrollers.  (Of course, you are welcome to try, but I suspect that you will get an installation error.)
Kevin S.
(2,594 Views)
