Can I make an array display update from the bottom up
Array displays by default start at the top left and then, for a 1D array, expand down or to the right, and for a 2D array, expand down And right.
For display purposes, I am wanting to have my display update from the bottom up.  This will be for a 1D array.
Any simple way of doing this without filling and replacing all the upper cells w/ blanks or something and then replacing each cell as I go ?
Appreciate any thoughts.
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
Message 1 of 11
(4,055 Views)
Seems like a pretty nifty idea for an XControl.
The other way would be to make the default index display invisible and use a separate control to index in using property nodes.
The XControl method would work in Edit mode while the surrogate index method would only work during a run.
Message 2 of 11
(4,050 Views)
Message 3 of 11
(4,048 Views)
Reverse the array before writing to your terminal.  That is by far the simplest way.
Message 4 of 11
(4,027 Views)
Looks like I have a couple options to experiement with.
Simply reversing the array would not suffice for what I am wanting by itself.  If I want the array display to show perhaps 25 elements, I would expand the display on the front panel to show that.  When it updated, even reversed, it is going to populate the display top to bottom.
A method to counter that would be to adjust the number of rows displayed through a property node with each addition.  And I would either have to re-reverse or write some other code to keep the elements in order as collected.  However, even then, the display will expand in a downward direction as I increase the number of rows.  This means that the values in the array will constantly be shifting down as the array grows making it difficult to monitor the values as the elements are added.
Certainly doable but am hoping for something a bit more elegant.    Ideally, I will have a blank 25 row display and the values will populate from the bottom up.   Will have to look into the x-control.  Have never played with those so will take a little research.
I have some ideas now but any other options will be appreciated.
Doug
Message 5 of 11
(4,014 Views)
Perhaps using a Table will do what you want.  You will have to convert to strings and form it into a 2D array, but that might make what you want.
Message 6 of 11
(3,998 Views)
Can I populate a table from bottom up ?
Doug
Message 7 of 11
(3,995 Views)
You'll have to do it by manipulating an array of strings and inserting empty strings to the front, but you wouldn't have to do the resizing, etc.
Message 8 of 11
(3,988 Views)
Yea, That is what I was wanting to get away from.   A lot of manipulation for the effect.
Looked briefly at Xcontrols.  Never paid attention to that feature before.  Will have to spend some time figuring out how to create and use them.  I'm sure there are some examples in the help or online.  Just don't have the time right now.
Will play with some stuff as I get the app developed and see what I can come up with.
Doug
Message 9 of 11
(3,975 Views)
For a simple but effective answer, you could always tell the customer to mount his monitor upside down, then use an upside-down font 16x16_smiley-very-happy.gif.
(Sorry, couldn't help it, today I needed some levity)
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 10 of 11
(3,971 Views)
