Can I repeat a menu selection?
Is there a shortcut to repeat a menu selection?  For example I just realized I have a series of wires that I need to insert a Negate into.  So I right click the wire and go thru 3 sub menus to get the negate.  For the next wire I have to go thru the same sub menus again.  It would be great if a right click gave you an option to repeat the previous function with a menu item that said "Repeat - Insert Negate" or whatever the previous function was.
(2,690 Views)
Accepted by DennisNeedham
(2,673 Views)
Perfect!  That will be a time saver.  Thank you.
(2,663 Views)
