Can I run a LV2010 application developed in Win7 on a WinXP machine if I simply install the LV2010 run time engine?
thoughts or suggestions?
(2,541 Views)
Remeber about the differences in "System Default" paths and build your project accordingly.  The Default application directory, Default data directory and this vis path constants will help you avoid problems with installation on the targets.  Avoid using path constants like "C:\ProgramData\MyApp\" that path is only valid on Win7 - instead, use:
Since they return different values depending on the OS
(2,536 Views)
You can also use the Get System Directory VI (in the File Constants palette).
(2,532 Views)
