wiring problem - case structure and while loop
I am trying to wire the connections between the error signals in "niSwitch wait for debounce" block inside the case structure and the one input of the OR gate. Also, I am trying to wire the connection between the same input of the OR gate and the error signal of "niSwitch Close" block which lies outside the while loop. I am working on Labview 10.0.1. But the image I have attached is from Labview 11.0.
I have marked the area in the block diagram with a red square, as this VI is from Labview 11.0 and my computer which has the real drivers/test panels installed works with Labview 10.0.1 (as I mentioned before). So I want to get this connection working in my computer.
Thanks.
(3,415 Views)
Accepted by topic author NivethaShivan
This is a new feature of LabVIEW 2011 (See figure 8 here [link removed; article no longer available]).
In LabVIEw 2010, you simply need to unbundle the "status" boolean from the error wire using "unbundle by name" before wiring to the boolean operation.
(3,399 Views)
Thank you for replying! That was helpful.
(3,363 Views)
