Save File Locally from A Web Published VI
Hi everyone! I have published a certain vi on the web and it's perfectly working as it is designed. This vi displays the data in the spreadheet file. My questions is if it's possible for the client computer to save the original file (accessed from the server via internet) locally on his own unit/computer?
(2,444 Views)
Hi Benjamite,
I would need you to clarify your question. I would believe you are talking about a WebVI that generates a spreadsheet. And the idea is to save the spreadsheet directly on some client computer.
For this application, rather than that, I would recommend that you allocate the created the spreadsheet file on the server and create an access to the file through ftp or anything similar.
I hope this helps!
Carlos O
(2,419 Views)
