Can I run two vis at the same time when they are the same vi?
I have done a VI that I am going to use like a subvi, but I want to use this vis several times with different parementers (control values).
The problem is that I want to run these vis at the same time, but when I have done it I have realized that I can not execute them at the same time.
Can I do that? If it is not possible, why not? When you programm using C, you can call the same function with differents paramenters at the same time, in differents threads!
Thanks in advanced!
Graci
(2,477 Views)
Have a look at this thread. It should explain what you want to do.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000056400000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=multiple+instances&USEARCHCONTEXT_QUESTION_S=0
(2,476 Views)
