LabVIEW different versions in NI License Manager
I instaled LabVIEW 6.1 and I upgraded the remote front panel license to support more clients (five clients). Now, I have instaled LabVIEW 7 (without removing LabVIEW 6.1) and in the NI Licence Manager environment only appears This last version(LabVIEW 7) wiht the five licenses, but I want to use the licenses with LabVIEW 6.1.
(3,006 Views)
I'm afraid that there is no solution because once you install LabVIEW 7.0, in the NI License Manager, LabVIEW 6.1 entry will never appear and the remote front panel license belongs to LabVIEW 7.0.
The only thing is not install LabVIEW 7.0 on the same PC that LabVIEW 6.1 is installed.
crisR
(3,006 Views)
However, if you have installed LabVIEW 7.0 and LabVIEW 7.1, you will be able to see both versions on NI License Manager.
(3,006 Views)
