Can I safely run LabView 6.1 VIs on LabView 7.1?
Just curious to know if anyone out there knows whether or not I can safely run LabView 6.1 VIs on LabView 7.1? That's all I want to know. Thanks.
(2,794 Views)
If the 6.1 vi's are opened with version 7.1, they should convert to 7.1, and ran safely. do that all the time
(2,789 Views)
If you ever think you will need to open them again in 6.1, make backups. Saving backword is a little difficult with LabVIEW.
Hope that this helps,
Bob
(2,765 Views)
Going forward is a breeze.
Going backwards.... well.. until they improve time travel.. 😉
Especially if you plan to go back to 6.1 from 7.1...
Message Edited by JoeLabView on 06-02-2005 02:25 PM
(2,761 Views)
