Can I setup visa events in an event structure or rather register dynamic visa events in an event structure?
Hi tlay,
Thank you for using the National Instruments forums.  In terms of your question, I am not sure why you would not be able to VISA events in an event structure.  I have set up a basic program, and it does not seem like there are limitations.  Is there something specific that you are trying to do, but you cannot get to work?
If you are still struggling to get VISA events working within an event structure, please give me a little more information on what you are trying to do in particular.  I believe that it should be possible, but for specific help, I will be more likely to be able to solve the problem if you give me as much information as possible.
Lauren L.
Applications Engineering
(2,402 Views)
