Can I solve system of equations in labview????
Hi all !!!
I would like to know, can I solve system of equations in Labview?
For example,
5a+7b=15
19a-4b=125
(Of course, real equations have much more difficult description...)
Thanks in advance.
Message 1 of 24
(12,818 Views)
LabVIEW, like any other programming language won't solve simultaneous equations for you. However, if you can define the problem, you can work out a solution. Think in terms of inputs, outputs and algorithms.
If you want some help working out a maths function, we can help you out
_____________________________
- Cheers, Ed
Message 2 of 24
(12,808 Views)
The linear system you showed can easily be solved by using "solve linear equations".
I have no idea what you mean by "real equations"?  Do you simply have more unknowns and larger matrices? If your real equations are completely different, you should probably give a more specific example.
Message 3 of 24
(12,802 Views)
Thanks for your replies!!!
Here is my equations:
9.91168E-14=F0*(exp(-Alfa* 4.455E-5)-exp(-Alfa*0.0001)/(1+0.00005*Alfa))
1.05472E-12=F0*(exp(-Alfa* 4E-5)-exp(-Alfa*0.0001)/(1+0.00005*Alfa))
I must find values of Alfa and F0.
Can you give me the way of the solution?
Thank you in advance..
Message 4 of 24
(12,779 Views)
Your two formulas are the same except for a constant and could be described as y=f(x):
y(x)=F0*(exp(-Alfa* x)-exp(-Alfa*0.0001)/(1+0.00005*Alfa))
And you have two points:
1. (x=4.455E-5; y=9.91168E-14)
2. (x=4E-5; y=1.05472E-12)
You could simply use a nonlinear curve fit with the above formula model and the two data points to find F0 and alpha.
Message 5 of 24
(12,657 Views)
OK. Thank you so much.
I'll try it.
Message 6 of 24
(12,653 Views)
Dear Altenbach,
I tried to use nonlinear curve fit, but I have some difficulties...
Please, send me an example, if you can...
Message 7 of 24
(12,650 Views)
Fourteen minutes wasn't a long time to try.  If you are having problems, you should post what you tried so Altenbach can see where you are going wrong and suggest improvements.
Message 8 of 24
(12,633 Views)
What are the difficulties? (starting LabVIEW? writing the program? fit does not work? computer bursts into flames?)
What is your LabVIEW version?
Do you have a reasonable guess for F0 and alpha?
Message 9 of 24
(12,630 Views)
I don't understand where I must write my formula...
Message 10 of 24
(12,616 Views)
