Can I subset an array (from excel) by time values for length?
Is it possible to slice portions of an array by time value per iteration? I am looking for a way to take a data sheet (taken from Excel) put into an array and then portion out 10 minutes at a time. The data sheet does not have exact sequential time value otherwise I would just use sample size (i.e. 600 for 10minutes). Instead of sample size can I search and subset by a time delta? I appreciate all the help I can get.
Message 1 of 18
(3,842 Views)
Probably, but you'll need to provide an example of how your data has been stored in Excel.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 18
(3,836 Views)
Hi Travo,
yes, you can.
I would transform the time values into timestamps and then use standard comparison functions to search the correct data range...
Message 3 of 18
(3,833 Views)
Great GerdW, i am glad to hear that its possible. I was having a heck of a time trying to figure out how i would do that. Now I just have to figure out how to do what you are suggesting.Ha
I have attached my VI and a 20minute example. My VI is setup to subset by sample size right now.
Message 4 of 18
(3,825 Views)
There's a 'Seconds' column in the spreadsheet already.  It appears to be elapsed time.  It will be much easier to use that.
Message 5 of 18
(3,819 Views)
Hi NIquist,
that "Seconds" column is more of a counter when you compare it with those two timestamp columns...
Message Edited by GerdW on 03-16-2010 04:25 PM
Message 6 of 18
(3,816 Views)
Hi NIquist and GerdW, yes the "seconds" column is sort of an "elapsed time" (total) since the machine's start date. I have used it previously but for different things, for this instance I am hoping to capture 10minutes at a time in sequential order, once the data is set aside, i want to run it through a set of subvi's to count cycles for that 10min period. I then wish to write each 10min value to another sheet to include ending time-stamp, so each value should have a time-stamp incremented by minutes from indexed stamp.
does that help a bit?
Travo
Message 7 of 18
(3,813 Views)
They look equivalent to me.  I see the timestamps going for 20 minutes.  The Seconds column goes from 7847295 to 7848495 = 1200 seconds = 20 minutes.
Message 8 of 18
(3,809 Views)
Hi Travo,
could you please convert the "xlsx" to a more common xls - or even better a tab separated txt? At home I can't open your sheet...
Also all the subVIs are missing in your VI. From what I see I would suggest to use a different conversion as you have different datatype to convert (numbers, timestamps...)
Message 9 of 18
(3,778 Views)
Hi GerdW,
 Let me know if this works. I have put the VI into a project and created a shared library too. Dont know if this will work but if it doesnt I can just send all of the VI's together instead. I also included the xls file.
What do you mean by different conversion?
Message 10 of 18
(3,774 Views)
