Can I trace and probe active code in a 7030 RT controller using Labview 6.1 while the RT engine is running?
Can I trace and probe active code in a 7030 RT controller using Labview 6.1 while the RT engine is running? Labview 6.1 is installed in an embeded pxi controller which concurrently runs a testing app.
ceaso
(5,837 Views)
ceaso,
I haven't actually never used this combination. When you try to run your program with highlight execution enabled, are you getting an error? What have you tried and what was the result? Is your app an executable or is it in VI form?
Let us know. Thanks!
Chris C
(5,796 Views)
HI Chris
The app is in .vi form and it calls the RT.exe. I tried it and got no error, but it hung up during the trace.
thanks
(5,783 Views)
Hmm..... are you able to run any VI with highlight execution turned on? Does even a simple VI hang?
What do you mean "The app is in .vi form and it calls the RT.exe." Do you have a VI on your computer that somehow calls an executable on your RT target?
Chris C
(5,666 Views)
