Can I use LabView to implement an array of microphones for localization of sound?
thanks John,
now its clear, how to ask for help in here.
I'll work with the tutotials and try to put out an algorithm.
Please post any similar projects if you know any, like hueter did.
P.S. I didnt wanna be rude to Ray. My apologies.
Message 11 of 24
(2,360 Views)
dummy316 wrote:
thanks John,
Just as an aside, johnsold's name is Lynn, not John.
Cory K
Message 12 of 24
(2,352 Views)
I didn't ask for you to publish your methodology in public.
I was referring to design of the LabVIEW code so that you could ask for help in a better way.
Message Edited by Ray.R on 09-15-2009 01:26 PM
Message 13 of 24
(2,341 Views)
gotcha dude...
chill !
Message 14 of 24
(2,314 Views)
Probably other papers/thesis may useful.
A good place to see more about current achievements is LEMS.
P.S. I am not with Brown.
Message 15 of 24
(2,300 Views)
If you can dream it, LabVIEW can do it 🙂
I hope you post the results of your project (maybe a sweet report, not the code/hardware) when you finish. Sounds sweet.
[will work for kudos]
Message 16 of 24
(2,296 Views)
Someone who is more biased on MATLAB is insisting on using it rather than LV for my project.
can anybody here who has substantial experience with MATLAB, help me decide on this please?
Please provide me the advantages and disadvantages of using either of them if you can.
Message 17 of 24
(2,245 Views)
It all depends on how comfortable you are with a language.
If it is C/C++, then do it in C/C++
If it is MatLab, then do it in MatLab
If it is LabVIEW, then do it in LabVIEW
They all have their benefits and low points.
The one thing that I do admire about LabVIEW and to a degree CVI is the superb support that you get at this forum.  Try to get this much help on other forums, for VxWorks, C/C++ or MatLab.
Message 18 of 24
(2,233 Views)
CVI was tough for me to learn because I did very little text programming - and that mostly ATARI BASIC on an 800XL.  (Okay, I did some VB .NET along the way, too.)  But once I learned how easy it was to do what I specialized in - ATE software - in LabVIEW, I dropped text programming like a hot potato.  At least CVI generates a lot of the basic code for you.  I guess the other hard part was that I was learning C++ programming on the fly.  😉
Bill
Bill
CLD
(Mid-Level minion.)
Message 19 of 24
(2,229 Views)
Hi All,
I want to implement the sound localization project in labview in real time.
i have an array of 4 microphones and i am using NI DI-158U DAQ but i could not able to get the data from the DAQ using ultima serial.
Can any one please help me with respect to whcih DAQ device can help me collect the data of the 4 microphones or even more to load using the labview DAQmx.
Thanks and Regards,
Harsha
Message 20 of 24
(1,898 Views)
