Looking for Boonton 9242 Instrument Driver
I am looking for an instrument driver for a Boonton 9242 RF Voltmeter. Any help appreciated!
Message 1 of 9
(4,101 Views)
Accepted by topic author tylerH
Is that instrument SCPI compliant? If so you don't necessarily need drivers for that exact model.
SCPI defines standardized interfaces for several kinds of instruments -- including voltmeters.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(4,095 Views)
I do not see a specific driver for the device but, the device is SCPI compliant and a few hours of work starting from a Instrument Driver Project Template would get one ready to go.
[Edit] Adding to Mike's post... RF Voltmeters are not well defined in "Compliant Capabilities" but, go ahead and start with an RF Power Meter template... There are a lot of DMM functions that are NOT available to that device
(Mike, Really? ......)
The meter really is simplistic in its "MEASurment:XXX" functions and would be a great way to learn how to write an Instrument Driver for a SCPI Compliant device..... I'd pass it to any intern for a learning experience!  (And yes, I'll answer questions from them)
Message 3 of 9
(4,088 Views)
Thanks Mike and Jeff, trying to help our programmer out with a done solution. Was hoping someone had a driver they knew of.
Message 4 of 9
(4,084 Views)
In case no one has one - http://www.ni.com/tutorial/9097/en/
Message 5 of 9
(4,066 Views)
Thanks Mike, trying to help our programmer out with a done solution. Was hoping someone had a driver they knew of.
Message 6 of 9
(4,063 Views)
See the edit to my last post... Instrument Driver Templates would make that fairly easy
Message 7 of 9
(4,050 Views)
OK, thank you Jeff and all, this is my first post and I am impressed with the rapid replies, I just had a discussion with our guy, I think he will be able to handle it!
TylerH
Message 8 of 9
(4,044 Views)
TylerH
Keep posting.... We like the easy onesSmiley Very Happy
Message 9 of 9
(4,033 Views)
